How do I remove trusted personal devices. Each time I log on to my new iPad it wants to send a push notification to my old iphone. If I choose a different method, it lists at least 3 personal mobile devices I no longer have.
Have you tried email?
@ctrad64 wrote:
How do I remove trusted personal devices?
Go into your account profile in the app (or my.arlo.com) and then select "two-step verification". In the app, swipe left on devices you want to remove, and you will see a trashcan. In the browser, there is an edit control at the bottom of the page (easy to miss).
You should be able to trust the iPad from that same screen. Touch the + in the upper right, and you should see a "trust this device" option.
Also, you can change where the push notification is sent by simply touching the device you want to use for that.
Arlo Ultra 2
Prima di acquistare
