Hi all, having issues with tinycam pro
"Value Unknown of type java.lang.String cannot be converted to JSONObject" error when integrating Arlo Ultra 2 cameras with tinyCam Pro!
All cameras, HUB and tinycam pro firmware are up to date, using tinycam pro on Amazon Firestick 4k and it’s the latest version and the app is in Developer mode, I have the correct username and password any help would be greatly appreciate, thanks
regards
Rob
@RobLun wrote:
Thank you for your support, is there a way of getting in contact with TinyCam author,
AFAIK, only this:
I think you'd need to talk to the Tinycam author about this. It may be due to an Arlo change but Tinycam will have to accommodate that change.
Thank you for your support, is there a way of getting in contact with TinyCam author, any link or contact details, cheers
Regards
Roberto
AFAIK, only this:
Thank You StephenB very Much Appreciated
Still not resolved, I emailed Alexey about 1 week ago still no reply, anyone else on here having this issue, Thanks
Arlo Ultra 2
Prima di acquistare
