System offline after power outage
Every time the power goes off even for a second even if I’m away from home I gotta wait till I get home and reinstall everything big inconvenience. Is there a shortcut to prevent that it happens all the time power goes off I gotta sit down and uninstall my hub and reinstall the hub then reinstall each of my five cameras every time Looks to me like when the power comes back on everything should be up and running
FWIW, mine does.
One option is to get a UPS, and use it to keep the base running through short power failures.
Arlo Ultra 2
Prima di acquistare
