  • 11 Replies
  • 862 Views
Sarannah
I have three Ultra 2 cameras, and an essentials doorbell. None of them work the way I expect the smart detection to work.  I've attached pictures of the settings I use, and the results in my feed.  Basically, all motion is captured. I get hundreds of videos a day, and they are all worthless because a leaf blew in the wind and the camera decided it was excited and needed to be recorded.  It is even better now that I turned on the AI captions so that I know I have a "Quiet residential pathway scene".
Is there any way to make the smart detection actually work?
@Sarannah wrote:
I have activity zones set up to exclude the street.
That will prevent motion on the street from triggering the camera, but won't affect the classification engine (which AFAIK ignores activity zones).
11 REPLIES 11
Are you also getting notifications for the "quiet residential pathway scene" recordings?
Sarannah
Yes.
I especially like the AI overview that says, "the scene is peaceful with no people, animals, or vehicles..."
Is object detection set up the same way for all your cameras?
Sarannah
Yes
@Sarannah wrote:
Yes
The AI scene description overrides the object detection tag.  In your specific screenshot, there is a vehicle across the street (upper left).  So it is possible that
  1. something moving triggers the camera
  2. the classification engine notices the vehicle, and tags the video as vehicle.
  3. since that is enabled, the cloud creates the scene description and sends the notification.
Not certain that is happening, but you could try aiming the camera a bit lower as a test (taking the street out of the field of view).
Sarannah
This was happening before I turned on the ai scene detection.
I just have nice descriptions of it not working correctly now.
I have activity zones set up to exclude the street.  Would the scenario you proposed still happen?  The thing that also still would make sense to me is that say a leave blows in the activity zones set and a truck drives by at the same time and it picks that up, why would I get a generic motion tag and not a vehicle tag?
Sarannah
So the classification engine is worthless?  Got it.
what a waste of $1000
Not worthless.  It just always covers the full field of view.  There are scenarios where that is a good thing - for instance, if the triggering object is moving fast enough to be out of the zone for the bulk of the recording.
Sarannah
If the feature were properly implemented it would use activity zones.  I don’t need 100 notifications a day because a car happens to drive by at the same time a leaf blows in the wind.  If I wanted the street included I would have a zone over the street.
We agree this could be improved, though I personally think the right answer is to block notifications/recordings for blowing leaves, grass, and similar stuff (whether you are using activity zones or not).
FWIW, some of the cameras have privacy zones, and those are applied when the image is captured.  That would help in your case, since stuff in the privacy zones wouldn't be presented to the classification engine.  But unfortunately, the Ultras don't support privacy zones.
  • 11 Replies
  • 863 Views
