  • 1983 Views
smokinsambo
Which smart hub ultra or pro comes with “The Wireless Doorbell + 4K Camera Bundle”?
4k cameras are the Ultras which likely means the hub is the VMB5000.
smokinsambo
Tks jguerdat. Assumed it was the 5000 model but did not see where it was stated in description.
Agreed although it really doesn't make much difference other than the local recording method (the 5000 uses a microSD card while the 4540 uses a USB port. The 5000 also supports both 2.4 and 5 GHz connections if 2.4 congestion is an issue.
The item # shown in the description is VMS5240-200NAS which also tends to support the idea that it's a 5000 that's included.
  • 1983 Views
