SD card problem in hubs
the Hubs only said my sd card had error. My sd card is a new one. The software had a format button but I cannot use it. How can I solve the problem
Have you checked it in a PC? Making sure you could both read and write to it?
How large is the card? Who is the manufacturer?
The problem is solved Thank you
Arlo Ultra 2
Prima di acquistare
