  • 4 Replies
  • 4818 Views
RIPOC
In 2021 I bought 3 Arlo Ultra 2 cameras and a base station and set them up with local storage to a micro disk. Never had a paid subscription. Cameras have worked fine and all along I have been able to view the library videos stored locally.
 I upgraded when informed of the app upgrade to benefit from any bug fixes or security patches. Once done I was unable to view any videos locally stored. The app indicated this was a premium subscription service. Called the number I used for tech support in the past, but it was disconnected.  Is there a fix for this or can I reverse the upgrade.
Using IOS 17.4
@RIPOC wrote:
I have walked in front of them and nothing happens. This leads me to believe the upgrade changed my settings.
Check the rules in the mode you are using.
Are you saying you now see "Feed" and "Dashboard" in the app, instead of "Library"?
If that is what happened, then you can still access local storage.  But it is not in the feed.  Instead
  1. go to the devices page
  2. select the VMB5000
  3. select storage settings
The recordings should show up on that page.  It's not as convenient as before - hopefully Arlo will put them into feed at some point.
Yes, now you can only get phone support through the app.  It requires a subscription (either trial or paid).
...can I reverse the upgrade.
You cannot go back to Library.
FWIW, the app itself has supported both of the interfaces for over a year now.  You didn't actually upgrade the app - what happened instead is that Arlo just switched your account to the new interface.
Everyone will eventually end up migrated to Feed - Arlo won't maintain two different interfaces forever.
RIPOC
Thank you, that was fast.
I see the videos now. Unfortunately the cameras seem to be activated even though both show as active. I have walked in front of them and nothing happens. This leads me to believe the upgrade changed my settings.
Under ‘local storage settings” status shows good and all the functions are enabled except ‘port forwarding’. And there is tons of storage space on the micro disk.
Any suggestions?
RIPOC
Thank you that did it.
  • 4 Replies
  • 4819 Views
