  • 8 Replies
  • 843 Views
Stevewins
Last night the major ice storm here in the Midwest knocked out power for 7 hours. Transformers were blowing up and lighting up the sky all night long, it was like the Fourth of July.  I have a battery backup on my Arlo base station but not on my router. I expected that my VMB 5000 base station with SD card would continue to record clips during the outage, even though I couldn’t view them yet without the wifi connection for the base. However, the base did not record anything during the outage. Shouldn’t it have?
8 REPLIES 8
If motion was detected by one of your cameras, it should have recorded on the microSD card.
Stevewins
That’s what I thought. Maybe my battery is worn out. I’ll do a power outage simulation and see what happens.
We happen to have few power outages of major length but my 750VA UPS died much quicker than I had anticipated a couple of years ago. I had figured on at least a few hours but got less than 1 hour. I have my modem, router and hub connected to it so I guess I need to revisit power consumption.
The UPS battery does degrade over time, so you might want to check if it is user-replaceable.
It's been changed. I have APC UPSes which all have replaceable batteries. I have no idea at this point how old the battery was - could have been recent or old then.
Power use does vary quite a bit for different routers (and perhaps modems).  But I think 30 watts total is a reasonable estimate of what a modem+router+base would use.  A 750VA UPS should give at least 2 hours at that load (per the APC calculator).
Stevewins
Mine stopped recording immediately, right after the outage began.
Did you try the power outage simulation you mentioned earlier?
  • 8 Replies
  • 844 Views
