I’m been looking for a screw on extension arm for the Arlo mount. I’d like to move the Ultra 2 out a few inches so it’s over the window sill. I see lots of taller mounts but not seeing anything that will screen on to the existing Arlo mounts to just extend. Anyone seen one of these?
5 REPLIES 5
First, any standard camera mount will work... 1/4-20 threads
Have you tried a flexible mount... there are many
or
there is always adjustable
Thanks.
I most likely can’t remove, replace or change the existing mount hence the question about an extension that could screw onto the existing mounted mount. A search around Amazon didn’t find any but I’m betting I’m not the first to ask about this so what why I asked here.
Look for coupling nuts in 1/4"-20 thread. You can then add your own extension bolt (cut the head off an existing bolt):
Thanks. What is this "extension bolt" ? I don't have any way to cut a bolt. Is there not an arm of some type made to just screw in?
Possibly - you'd have to look and/or ask sales folks or look online.
Arlo Ultra 2
Prima di acquistare
