Mount arm extension
  • 5 Replies
  • 4008 Views
Loyed
I’m been looking for a screw on extension arm for the Arlo mount. I’d like to move the Ultra 2 out a few inches so it’s over the window sill. I see lots of taller mounts but not seeing anything that will screen on to the existing Arlo mounts to just extend. Anyone seen one of these?
5 REPLIES 5
First, any standard camera mount will work... 1/4-20 threads
Have you tried a flexible mount... there are many
or
there is always adjustable
https://www.amazon.com/Arkon-Camera-Mount-Camcorders-Cameras/dp/B00CMLX1O2/ref=sr_1_8?crid=1CHRHEGB9...
https://www.google.com/imgres?imgurl=https%3A%2F%2Fwww.androidcentral.com%2Fsites%2Fandroidcentral.c...
Loyed
Thanks.
I most likely can’t remove, replace or change the existing mount hence the question about an extension that could screw onto the existing mounted mount. A search around Amazon didn’t find any but I’m betting I’m not the first to ask about this so what why I asked here.
Look for coupling nuts in 1/4"-20 thread. You can then add your own extension bolt (cut the head off an existing bolt):
https://www.amazon.com/s?k=Nuts&rh=n%3A16310091%2Cn%3A383599011%2Cn%3A16409861%2Cn%3A16409941%2Cp_n_...
Loyed
Thanks. What is this "extension bolt" ? I don't have any way to cut a bolt. Is there not an arm of some type made to just screw in?
Possibly - you'd have to look and/or ask sales folks or look online.
  • 5 Replies
  • 4009 Views
