Motion announcements
Have my cameras hooked up to Alexa, and the motion announcements keeps shutting off to the point I have to go back in within 30 minutes and turn them back on. Anyone else having this problem
Hi @Perryd92
May I ask which setting you're having to turn on multiple times? Can you provide the steps to replicate?
Hi, I have 3 cameras hooked up to my Alexa, when I into my alexa app the motion announcements are off. I go to each camera and turn them on. Within 5 minutes I go back into the alexa app and there all off again. I also have 1 ring doorbell camera hooked up to my alexa with no problem.
Thanks for the info. Can you try removing the account from Alexa and re-add it if you haven't already.
Arlo Ultra 2
Prima di acquistare
