Lately I’ve started getting this error message whenever I access local storage from the iOS and iPadOS apps. It still works normally otherwise and everything is there and viewable. How do I stop this message from constantly re-appearing?
Have you tried force closing the app and reopening it?
I close it every time I’m done using it. I don’t normally leave apps running in the background. It gives this error every time I open it on either iPhone or iPad. This just started recently, the at last week or two.
Arlo needs the app to be backgrounded for notifications to work. Closing the app, as opposed to force closing, should allow the app to be backgrounded but maybe it's an iOS thing. On Android I simply use the Home or back buttons which works fine.
On every iPhone I’ve owned, the notifications work whether or not the app is open, backgrounded or closed. On my one and only Samsung/Android phone, the same is true, so I’m not sure what you’re talking about. This has nothing to do with the new error message when accessing the local hub.
What’s the difference between “closing” and “force closing” an app? I don’t think there is one.
Force close (sometimes called force quit) is described here:
Usually something you do when an app locks up.
I agree that the inability to access local storage is a very different problem from missed notifications.
That’s the same thing as “closing” the app. It’s the only way I know how to close an app on the iPhone and iPad. Do you know of another way?
Whether open, closed or in the background doesn’t affect notifications on any of my phones or tablets.
It is the only way to close an app with iOS. But @jguerdat uses Android, and it has a force stop option for each app in the phone settings. FWIW, it also has a clear cache option, which iOS lacks.
Perhaps I'm confused, but my understanding is that your issue is with accessing local storage, not notifications. Is that the case?
No. The issue I’m having is that when I access local storage, I get that error message every time. However, the recordings still populate and I’m still able to access them normally once I close the error message. I’m just trying to get rid of that error message from popping up every time.
Notifications work normally for me regardless of whether the app is open, in the background, or closed. @jguerdat mentioned that the app had to be backgrounded to get notifications, which is incorrect, at least for iOS and iPadOS and I think for android also.
Thanks for clarifying. I'm tagging the mods ( @JamesC and @ShayneS ) in case they want to follow up.
The notifications sidebar is just distraction, so maybe drop that part of the conversation.
I guess that depends on the definition of "closed". As long as the app is still logged in, it's backgrounded. If closed were to mean logged out, nothing is going to work in Arloland.
I agree, obviously if you log out vs simply closing/force closing the app then notifications won’t be received on that particular device. However, if the app is either being used in the foreground, running in the background along with another app being used in the foreground or the phone being asleep, or if it’s been closed/force closed, then the notifications will work. Regardless, none of these have anything to do with my original question.
If you mean this, I use the force close method on Android. Since iOS apparently doesn't allow this, log out and back in to see if that "fixes" the problem.
@jguerdat please leave this thread, you’re not helping, you’re just muddying the waters.
Just to clarify the symptoms:
You are getting the error message when you first attempt to access local storage. Does hitting "cancel" allows you to proceed (and access the storage anyway)?
If so, when does the error re-appear? The next time you open the app? Or perhaps when you leave the local storage screen, and then open it up again?
@StephenB There’s no correlation between the error message and the point in time at which I click on the library tab. Before I posted this thread, it was happening every single time I clicked on the library, whether it was right after launching the app, or simply switching from the devices, mode or settings tabs. Neither rebooting the phone nor reinstalling the app had any effect. Now, the last couple of days after posting this, it only occurs randomly when opening the library tab vs constantly.
All of my recorded clips are there and visible in the library tab just like normal, regardless of whether the error message appears or not, and once I close the error message, I can view the clips.
This isn't something I've seen here before - generally when that message shows up you can't access the library recordings at all.
I'm tagging the mods ( @JamesC and @ShayneS ), so hopefully they will follow up.
I will pass this topic along to the development team for further investigation.
Just to clarify, you are still able to view your recordings, the error message can just be cancelled, allowing access as normal?
That’s correct. I can close the error message and view my recordings normally.
Just to gather some more info...
- Is this happening when the iphone/ipad are connected only to your home wifi (cellular data disabled)?
- Do you have port forwarding set up? If so, is it perhaps set up to use port triggering?
- Is there a VPN enabled on the iphone/ipad?
No port forwarding, no VPN, no correlation to whether I’m on wifi or cellular.
Arlo Ultra 2
Prima di acquistare
