How to record people only, without any notifications
Hi,
I have a camera at the front of my property, pointed at my gate, which I have set with a schedule where at night, I receive smart notifications (and recordings) for any people movement only. This works really well.
During the day, I would like to set this to record people only but not have any active notifications at all as I receive too many. When I have tried to set the daytime mode to have no notifications, it records all movements (vehicle, animal, people, other) which is a real drain on the battery.
Is there any way that this setup can be achieved?
Changing the notification setting in the mode should not affect any of the smart filters
If you want to do it during the day you might have to set it up for schedules which means you would need a custom mode with notifications off
Then again you could just toggle off the notifications on your phone during the day
Having to turn on and off notifications on my phone every morning and night is a bit of pain!
IPhones have two modes which might help you that can automatically turned on and off according to the time. The modes are “do not disturb“ and “bedtime” mode.
How to Enable iOS 12's New Do Not Disturb at Bedtime Feature
- Open up the Settings app.
- Scroll to the "Do Not Disturb" section and tap on it.
- In the Do Not Disturb section, tap on "Scheduled" to toggle it on.
- Select your Do Not Disturb time period, which, for most people, should be from when you go to bed until when you typically wake up.
- Tap on Bedtime Mode to toggle it on.
With Bedtime Mode enabled, when you activate the display on your device, the entire screen is dimmed and black, offering up only the time, the current device charge, and a notice that Bedtime Mode is turned on.
Arlo Ultra 2
Prima di acquistare
