Stuck camera in case?..
  • 2 Replies
  • 3304 Views
alexsunny123
Hello,
Camera is stuck in the case and the key release doesn’t work.
thanks
alexsunny
Assuming you just have the camera and not the security mount, I've had a few occasions where the camera didn't p;op out far enough for my fingernails to be able to grab the edge of the camera. I found that using one hand to hold the camera face down with the other hand ready to catch it and then using a hard shake to use the weight of the camera along with the shake would cause the camera to pop out of the case. Be careful to not drop the camera as it releases.
alexsunny123
@alexsunny123 wrote:
Hello,
thanks
alexsunny
thanks my issue has been fixed.
  • 2 Replies
  • 3305 Views
