VMB4540r2 I have Arlo smarthubs in two homes which I need to arm and disarm independently. This worked simply in the previous software version. The new update makes this task quite unclear.
The three modes ("Armed Home", "Armed Away", "Standby") are not system-wide - you get these three modes for each location you have set up.
So create a new location for the second home, and place the cameras and smarthubs in the appropriate locations.
(Note it is simplest to create a new location for the home you are currently at, since you will need to remove/re-add the cameras and the associated smarthub from your account in order to move them into the new location).
Note that each location requires its own subscription. Though of course you can go with local storage for one (or both) homes.
OK thanks for your suggestions.
Arlo Ultra 2
Prima di acquistare
