  • 4 Replies
  • 2443 Views
  • 2 Likes
nhughes29
I am looking to buy 3 Ultra 2 security cameras and was wondering if the required base station comes included.
It does not say the base station is included in the "What's in the box" but I think the photo with the cameras and station in the background is misleading.
Just want to make sure before I place an order.
Thank you in advanced.
As the above, it depends on exactly what you're looking at. Since you can buy single cameras, the hub isn't included in all packages. You need to look for the package that includes the hub or arrange to buy one separately. Note on the following link there is a single camera as well as kits. The kits have hubs included.
https://www.arlo.com/en-us/cameras/ultra/arlo-ultra-2.html
Dgmi
It prob depends what package and where you’re buying it from.
the ones I got was from Best Buy and came with 3 cameras, base unit, batteries and charger..basically everything you need.
DannyBearAgain
I think that “what’s in the box” is a good indicator of what is actually in the box.
nhughes29
Thank you so much! This was the kit I was looking at and they don't list the Hub in the 'What's in the box" - thus the confusion.
  • 4 Replies
  • 2444 Views
  • 2 Likes
