Hello,
Can Arlo take a quality video in the dark? Do I need an external IR lamp to make it work?
thanks
alexsunny
All Arlo cameras have the ability to record in darkness via IR LEDs or built-in spotlights. You didn't specify which camera models although this is the Ultra 2 section. Many of the newer cameras use the spotlights so you get color recordings at night while the IR ones result in B&W.
Arlo Ultra 2
Prima di acquistare
