Does the Arlo Camera have night vision capabilties?..
  • 1 Reply
  • 3412 Views
alexsunny123
Hello,
Can Arlo take a quality video in the dark? Do I need an external IR lamp to make it work?
thanks
alexsunny
All Arlo cameras have the ability to record in darkness via IR LEDs or built-in spotlights. You didn't specify which camera models although this is the Ultra 2 section. Many of the newer cameras use the spotlights so you get color recordings at night while the IR ones result in B&W.
  • 1 Reply
  • 3413 Views
