Connecting two soloar panels to one Arlo Ultra 2 camera?
Depending on the sun movement of summer/winter I need to move the solar panel on one Ultra 2 camera to get full sun. Is there a splitter to connect two solar panels to one camera? If not, is there another solution someone has found?
No such thing unless you made one yourself. I find I just change the angle 2x per year - winter and summer but sometimes not at all. While there's a big difference in the angle, it's not like the sunlight isn't making power on a mis-pointed panel. My cameras have more of an issue due to temps (<32F so no charging) than solar panel aiming.
Is there a way to connect 2 cameras to same solar panel?
I have 2 cameras on one corner/side, pointed in different directions. would like to charge both cameras from same solar panel…
are the arlo solar panels strong enough to do that? are such cables available?
No.
Arlo Ultra 2
Prima di acquistare
