Connecting two soloar panels to one Arlo Ultra 2 camera?
  • 1254 Views
Dan6117
Depending on the sun movement of summer/winter I need to move the solar panel on one Ultra 2 camera to get full sun.  Is there a splitter to connect two solar panels to one camera?  If not, is there another solution someone has found?
No such thing unless you made one yourself. I find I just change the angle 2x per year - winter and summer but sometimes not at all. While there's a big difference in the angle, it's not like the sunlight isn't making power on a mis-pointed panel. My cameras have more of an issue due to temps (<32F so no charging) than solar panel aiming.
Dgmi
Is there a way to connect 2 cameras to same solar panel?
I have 2 cameras on one corner/side, pointed in different directions. would like to charge both cameras from same solar panel…
are the arlo solar panels strong enough to do that? are such cables available?
No.
  • 1255 Views
