  • 5 Replies
  • 1109 Views
Chantal2020
I’m not able to view my cameras in 4k from my ipad air 2. Everything is updated…cameras, hubs, ipad and although I can see them in 4k from my iphone, I can’t view them in 4k through the ipad. I have a different account set up on my ipad so it doesn’t log me out from my iphone everytime i view from the ipad, and yes it’s connected to the same network as my hubs/cameras and i have granted administrative rights to the account. What am i doing wrong? Has this happened to anyone and if do how did you resolve this? Thank you!
5 REPLIES 5
I believe that's a limitation of that iPad model - it doesn't support the HEVC codec needed for 4K playback.
Chantal2020
I can see it in 4k with my account on the ipad, just not with any other accounts i have granted administrative rights to.
This is with the ipad air 2?  Or a different model ipad?
Either way, if you are livestreaming 4K in the friend accounts, try instead to see if you can see 4K in the recording library.
Chantal2020
Yes air 2
And yes the library recordings are also in 4K however the only thing that doesn’t show 4K is a live view from the 2nd account with administrative rights.
Then it's clearly not an issue with the iPad supporting the codec.
It must be a restriction in the friend account access to livestreaming.  Are you seeing this in another device (supporting 4K of course) using the same friend account?
  • 5 Replies
  • 1110 Views
