Can I connect the Arlo base station without a Ethernet cable and just use wifi?
  • 1 Reply
  • 4550 Views
TheoBeland
Can I connect the Arlo base station without a Ethernet cable and just use wifi? I just got the Starlink system and it doesn’t have a Ethernet port🤷‍♂️
The Arlo base requires an Ethernet connection  ( you can not connect via wifi ).
You can get a WIFI extender with an Ethernet port... connect the extender to you home wifi and plug the base into that.
  • 1 Reply
  • 4551 Views
