Camera waterproofing issues
  • 2 Replies
  • 2248 Views
Andrewjl
Hi,   The rain here can drive horizontally at the cameras and I am finding water getting between the Magnetic power connection underneath and the Wasserstein Solar panel connected to it.  The cameras have been mostly in place for 2 years now and I have experienced loss of charging and can see corrosion on the connectors of (currently) two cameras on the exposed side of the house. Cleaning the connectors resurrects the power connection. But I'd rather stop it in the first place.
The Cameras do have the Wasserstien skins over them, but as the connector is still uncovered this makes little difference.
My mind is thinking along the lines of a grease overlay, But this could be messy and temporary. Has Any one got experience or suggestions?
Andrewjl
Thanks TomMac.
I'll take that route and see how we go.
It appears that the skins aren't really doing anything
Andrew
I really can't think of another way since the magnetic connection isn't real water tight...
But I can see cleaning the contacts on both camera and charge wire then connecting. After doing so, I would use Dielectric grease at the contact seam to prevent water entry... it doesn't need alot.
Andrewjl
Thanks TomMac.
Andrew
  • 2 Replies
  • 2249 Views
