CVR timeline green line grey line
Why does my cvr show a grey on the timeline and green on the timeline above but then it just shows grey what is this. And what is this tracking like line in the middle of the video.
The "broken" green bars indicate recordings that should show up in Library or Feed. The gray line just indicates the CVR recording. Any break in that means CVR wasn't recording.
Not sure what you mean by the "tracking like line" - I assume that's a reference to the video screenshot you provided. That would appear to be an issue with signal strength/quality causing the video to be somewhat corrupted. Do all videos show that?
Thank you for the info. I was worried the grey line was bad connection. The tracking like thing is hard to explain
Arlo Ultra 2
Prima di acquistare
