  • 2 Replies
  • 754 Views
Tiffers20
Came with the house. Base station working all year and yesterday it stopped connecting to the internet. It’s just grey. I changed cords thinking it was that. I rebooted internet. I factory rest the base several times.
Any other thoughts? Not sure it’s an ultra 2 either..
Dannybear
You need to tell us what LEDs are showing on the base station.
https://kb.arlo.com/000039100/What-do-the-LEDs-on-my-Arlo-SmartHub-or-Base-Station-mean
If the internet led is grey or off and power is green then the base is missing the Ethernet connection to the base station which could be a faulty Ethernet cable, a faulty router or indeed the base station is faulty.
Have you power cycled the modem router for the internet?
I'm a little confused on whether you are seeing an issue with your base, or with one of the cameras connected to the base.
The base model is on a label on the base (and starts with a VMB).
If you open up the camera and pull the battery, you should also see a label there, which will identify the camera.  That will start with a VMC.  If you post that here, we can confirm the camera model.
Note that if you reset the base using the paper-clip reset, you will need to remove the base and cameras from the account, and then re-add them.
  • 2 Replies
  • 755 Views
