Recordings to the local SD micro storage in the base station stopped recording from all 4 Ultra 2 cameras and doorbell for 14 days, then started again yesterday. This happens regularly. Why does recording stop and how can I prevent. The card is not full as it continues to record after a stop period. The cameras are all charged and operating as normal (some need charging fortnightly, annoyingly)
And how can I monitor to see if recordings are taking place, other than checking the SD card regularly
Thank you
What model base/smarthub do you have?
The base station ref is - VMB5000r4
Firmware version - 1.19.0.3_1237_68a8e53
We are having horrendous problems with the doorbell camera, needing daily charging, with a total discharge/drain time of around 12 hours. I wonder if this is running constantly (running into 2000 reminders/notifications on the app) or there is a short circuit in the unit, and this is interfering with the recordings on the base station. The doorbell is less than 5 months old, and replaced a doorbell that developed the same problem after just 2 months
Very frustrating !
Any advice is appreciated, thanks
Arlo Ultra 2
Prima di acquistare
