I use Apple devices to monitor my Arlo systems - in recent days they started sending a message about the AC power being disconnected and now have stopped sending video clips to my library - is this an Apple problem following their news OS software updates or an Arlo software problem. I get the notifications alerts but there are no clips in the library
If you recently purchased your cameras (3-4 months ago), then look to see if your trial subscription has run out.
You need a paid subscription for cloud activity zones, and (with current cameras) for cloud storage. Without a subscription, you can only use local activity zones - which do require AC power, and any camera newer than the Pro2 will lose cloud storage.
I have two stems working together.
A pro 2 system working on the free service and a second Pro 3 4-camera system working on the initial trial period and you have taken a subscription payment but the messages re AC power and a failure to record to the library. Do I understand from your response that the Pro 2 system will continue to work on the free service but the new Pro 3 system needs a subscription and that, despite taking payment it is shutting down?
I just pointed out that a lapsed subscription on the Pro3 would match your symptoms.
So if you have a paid subscription, then go into the app or web ui, and see if the camera is actually in the plan (using the manage cameras control).
@Oaktree2400 wrote:...you have taken a subscription payment
Nope, not me. I don't work for Arlo.
Arlo Ultra 2
Prima di acquistare
