Sure! Here's the translation into English:
Hello,
I’m reaching out for help with an issue related to Arlo products. I live in Warsaw, Poland, and decided to create a home security system using Arlo products. I purchased the Ultra 2 camera kit with a Smart Hub, Essential Indoor 2K cameras, and a 2K Video Doorbell. Additionally, I bought the Home Security System (with the Keypad Sensor Hub and All-In-One Sensor), Wire-Free Outdoor Siren, and Security Tag. I purchased the Arlo products on Amazon—some on the Polish Amazon and some on the American Amazon.
I downloaded the Arlo Secure app and set up the Smart Hub and Ultra 2 cameras, with no issues. However, when I tried to set up the Keypad Sensor Hub, I encountered problems. In the app, under the "Add Device" section, I don’t see the "Security System" subgroup. From what I learned, I should add the Keypad Sensor Hub there. I tried adding it under the Base Station/Hub section, but it won’t connect.
Could you please help me with instructions on how to set up the Keypad and get all the security system products to work together?
Thank you in advance for your help!
Hello,
AFAIK, the home security system (keypad+sensors) are only available in the US. That is why you can't add it to your account.
A work-around some have used is to create an account using a VPN that terminates in the US. You could then turn off the VPN and you should be able to add the home security system to that account. You would also need a US payment method if you want to get a subscription.
Arlo Ultra 2
Prima di acquistare
