  • 1 Reply
  • 2093 Views
5LO
I've read through many of the posts here, but still looking for a concise resolution to my signal problem.
Some say add another VMB5000 Smart Hub into the system and place close to some of the other cameras and it will increase coverage?
If I have 2 base stations I'm assuming I would need to pair 2 of the low signal camera's to the close Smart Hub? So when I log onto my Arlo it would  show 2 base stations with 2 cameras each?
If I have a subscription for the 4K and add another Smart Hub would I need to add a new subscription since I've added another smart hub or does it not matter and the subscription is based off how many camera I have and not how many Smart Hubs I have.
Can the 2nd smart hub be added to a WiFi Extender with ethernet ports and placed closer to the cameras that have the low signal.
Thanks in advance.
5LO,
You wouldn't need to change anything with your smart plans, simply add the additional SmartHub and sync the cameras.  There isn't a limit to the number of SmartHubs/Base Stations you can have on your account.
Yes. The 2nd SmartHub can be added to a WiFi extender providing the extender has an available ethernet port.
5LO,
  • 1 Reply
  • 2094 Views
