One of my Arlo Ultra 2 Camera's Siren goes off randomly at night. This has happened twice now.
How do I fix this? Found no relevant setting within the app. In the app you can only turn on/off the siren manually.
Please help, so we can all sleep at night.
Have you checked the rule for the camera in the mode(s) you are using?
Yes, I've checked all the settings in the app and found nothing wrong there.
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
I tried turning it on & off (it's off at the moment till the problem is fixed, I'm afraid of turning it on again and having to wake up at night again. Should I try again now?)
I looked for any app settings & updates. Found nothing wrong here.
Have you tired removing and re adding this camera to your Smart Hub?
Yes
Okay, thanks for the updates. I would suggest reaching out to the Support Team to further investigate this issue you are experiencing or request an RMA. You can find several options for contacting support though the Arlo Mobile App by navigating to Settings/System/Support.
Yes, I sent them an email the same day I created this community post. Still waiting for their reply.
Arlo Ultra 2
Prima di acquistare
