Arlo App Arrive/Leave Automation Can't be Saved
I use the Arlo App with "Feed" experience. When I setup an Automation with "Arrive/Leave", the automation setting disappears after I logged out (and then back into) the account. This renders the app unusable with geofence.
I need to log out/back into the account because I manage multiple Arlo accounts with different locations and different ownership. The same thing happens with all of the Arlo accounts I tried. This made me suspect something is weird with my app.
Steps I have already tried: -- I removed the app off my iPhone and re-downloaded the latest app. I removed the cameras and re-added them to my account. I made sure they have the latest firmware. I even erased all Arlo cloud and reset/erase all Arlo devices under the "privacy/content" section.
Any suggestions? Thank you.
Further information:
I have already followed all steps outlined in this document https://kb.arlo.com/000062825/Why-isn-t-my-Arrive-Leave-Automation-working
I just checked my iPhone. I am using Arlo app 4.10.6 at the moment, which I believe is the lates.
Thank you, I have provided this to the appropriate team and support will be reaching out to you as soon as possible.
Hi,
I am having the same issue, latest app version 4.10.5 om Android and can't save automations. Button is there but doesn't do anything when i press it.
Does this still occur with App version 4.11?
Yes, the Save button for Automations does not work with 4.11 on Android.
I got it to work by tapping specific people and selecting them. It wouldn't let me save if it was on "anyone" fyi
Sorry Shayne... didn't see your message. Was waiting a response after I sent you my screen recording.
Yes, I am still experiencing this issue. I cannot save an automation on Android.
Just tried that, and still did not work.
Are you using the Arrive/Leave automation or something else?
Yup arrive leave and when I tapped specific people the button worked. I HD the same issue and came her before doing that.
Still does not work for me...even if I choose specific people.
I can save the choice of people, but when it returns to the main automation screen, I still cannot choose save on that screen to save the automation.
Hmm did you name it and fill in every option? Sorry that did it for me hopefully someone can help.
Ok...so going through and saving every step of the way does the trick.
Thanks Taylor33!
Arlo Ultra 2
Prima di acquistare
