  • 16 Replies
  • 5892 Views
Jmjm
I accidentally removed a camera from my app and can’t figure out how to get it back. It’s still recording and working perfectly but I can’t see it on my app.
16 REPLIES 16
Do you see it in a PC browser (my.arlo.com)?
Are you using the primary account in the app?
Jmjm
I cannot see it in the browser either and yes, I am using the primary account on the app. I already tried unplugging and restarting the Smart Hub Base Station as well as re-syncing the camera. I still get the notifications pop up upon movement and can still see the recordings in my Library. Just can’t get the camera on my app.
I think you will need support to resolve this. Do you have a subscription?
Jmjm
Thx. I do not have a subscription.
Hopefully one of the mods ( @JamesC , @ShayneS , @JessicaP ) will see this, and escalate.
One option is to purchase a subscription, and then cancel it after the problem is resolved.  They will rebate the unused portion of the month when you cancel.
ShayneS
Hi @Jmjm
Are you still experiencing this issue?
Jmjm
Yes. I don’t know what to do to get my camera back on my app so I can watch it live????
ShayneS
Do you see the camera listed in your Device settings > My Devices in the app? Have you tried to factory reset the camera by holding the sync button for 15 sec?
Jmjm
The Camera is not listed in my Device Settings. It disappeared when I accidentally hit 'Remove Device'.  I tried to 'Add New Device' but it does not show up. It still records activity that I can pull up from My Library.  But I cannot pull up live feeds nor do I get notifications of movements like my other 3 cameras and the way I used to for this camera. I tried resetting the Smart Hub/Base Station but did not know there was a factory reset for the camera? I will try that later today. Thx for your assistance.
ShayneS
Hi @Jmjm
Did the manual reset on the camera work? Were you able to readd and live stream?
Jmjm
Unfortunately the manual reset did not correct the issue. Still records but same problems - not visible on my app and no live stream. Other ideas?
ShayneS
Hi @Jmjm
Do you mind providing a screenshot of the missing camera in your device list. Also I would lie to look in to this further for you. The development team would like to request a device Log for troubleshooting if possible, if you don't mind.  this occurring on iOS or Android?
Jmjm
So now only 3 cameras visible. iOS.
ShayneS
Would you like to provide a trouble shooting log for me? I will need to know if yo are on Android or iOS
Jmjm
iOS
I've tried Adding Device, both automatically via search and Manually as well as Resetting the home base and the camera. Anything else you need?
ShayneS
Hi @Jmjm
  • 16 Replies
  • 5893 Views
