Able to hook up 2 Ultra 2 SmartHubs on the same network?
Would like to know if you can hookup 2 Ultra 2 Smart Hubs on the same network, will have to different routers, at different locations, plus will have several TP Link access points. Will be connecting 4 Ultra 2 cameras to the network also.
Karrel
Yes you can. I have a number of hubs connected to both the same and to different networks all in the same location. All appear in the same app.
Arlo Ultra 2
Prima di acquistare
