What is the diameter (thickness) of the 25-ft. Outdoor Magnetic Charging Cable compatible with the Ultra 2?
6 REPLIES 6
I don't know the thickness of the cable itself, but the connector head is 0.87 x 0.63 x 0.33 in (22.06 x 16.12 x 8.45 mm).
The cable is integrated with the adapter, so if you are wanting to pull it through a wall, the connector head size is what you need to know.
I’m not pulling it through a wall. I am securing the cable to woodwork with clips so I need to be certain the cable will fit into the clips which are rigid.
Makes sense. I have the cable, but don't think I have a way to accurately measure the diameter.
Would you say that the outdoor cable looks the same thickness as the indoor cable or thicker?
Thicker. I got an approximate size of .155" using vernier calipers.
Also, it is round (not flat).
Arlo Ultra 2
Prima di acquistare
