Hello Arlo Customers,
We are aware of a reported issue for some customers where the Arlo Base Station is appearing offline. We are actively investigating this issue and working to resolve it.
If you are currently experiencing this issue please reply to this thread with the following details so we can further isolate the issue:
Base Station firmware:
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.):
Internet Service Provider:
Exact error message:
The application used (iOS, Android, Web):
We apologize for the inconvenience,
Arlo Team
First the cameras worked but not device and mode following an update. The Mode and device showed offline.
When I got support, base station no longer worked so now I have nothing.
Model: pro
Isp:infinity
Cell phone Android.. can't connect.. getting status then offline.
Regular computer (win10) web access/login.. I can see the cameras fine.. but not the home base to change mode.
Base Station firmware: unknown ... ABOUT on the web shows : 2.4.13.870_20870
Device type showing offline Arlo Pro
Internet Service Provider: Comcast
Exact error message: Device offline, try to connect to the mode and it tries to connect but then shows offline
The application used Android and Web
If I refresh the site from a browser I can get a live feed as long as I do not connect to the mode page. It is not detecting motion and storing my videos or maybe it is and the station can't tell me.
Hello,
I am having this problem. It occured somewhere between the last video recorded at 2:58 am EST and when I left the house at 7:00 am. All cameras are showing the that base station is offline and it is listed as such in Mode. The base station itself appears fine with all the necessary green lights as usual. I have already restarted it by pulling the power, waiting, and plugging it back in. It came back up but did not fix the issue.
Base Station firmware: 1.9.8.0_16666
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.): base station / 4 Arlo / 1 Arlo Pro
Internet Service Provider: Verizon FIOS
Exact error message: Base station offline
The application used (iOS, Android, Web): IOS & Web (PC)
Model No VMB3010r2
Base station firmware: 1.10.0.4_20963
Device Type Showing Offline: Arlo
ISP: Verizon FIOS
Android and Web
This morning, both the ARLO base station and its 4 cameras were offline. I was able to restart the base remotely, and both it and 1 camera only came back online. I'll have to resynch the remaining 3 cameras manually I suppose. Oh, and there was something else really weird: the Alley camera continued to record even though it had an offline error message. But get this, the recording was showing under Carport 2 device both Android and Web.
Error message base station offline
Same here. It happened from May 14 2018 1am
No motion sensed recording. No battery status shown. LIVE view works.
- Base Statjion offline. Not possible to get.
- Arlo Pro, and Arlo Pro2
- Comcast
-Your Arlo device appears offline
- Web and iOS
My Devices status: getting information
Arlo app on IOS (todays update)
ISP: fiber 1000 Gbit/s from Denmark, Europe
Sky broadband
No internet detected. iOS app
Device type showing offline - Arlo Pro 2
Internet Service Provider: COX
Exact error message: Arlo device is offline...
The application used - Android
Device type showing offline: Arlo Pro
Internet Service Provider: Mediacom
Exact error message: Your base station is offline. Check that it is powered up and connected to the Internet.
The application used (iOS, Android, Web): iOS and Web
System was detecting motion this morning when it should not have been. Opened iOS app and it said that the base station required a firmware update. Clicked on update and it has been offline since. Base sation is powered on (green solid light), cameras are connected (green solid light) and internet appears connected (green occasional blink).
Hello,
model is VMB3010r2 with serial no. 48E35C76A1358.
Firmware most likely the latest. Last recordings were from 2:40 AM GMT this morning. All 3 LEDs are green on base station. Power cycle base station does not change anything.
Live view is possible for one of three cameras. During live view recording or snapshots are greyed out. Trying live view on one of the other two cameras results in offline message for all cameras until logging off. Web view or app on iPhone show the same results.
Base Station firmware: No idea, it's offline and I can't see it's firmware or the cameras
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.): Arlo Pro
Internet Service Provider: Comcast Xfinity
Exact error message: Offline
The application used (iOS, Android, Web): Android and Web (Chrome)
When I try to access the base station modes or hardware/firmware to look at versions I can't see any of it, it sits there saying "Getting status" and eventually changes to "offline". It's clearly not offline, however, because I can live stream the video. I'm just not getting push notifications for motion and there are no videos recording/uploading to the library since yesterday.
Arlo Pro2 - all 5 cameras showing same message.
hardware VMB4000r3
Mediacom Internet Provider
Shows the following error message "Your base station is offline...check to see if it is powered up and connected to the internet"
viewing the same message on the following software iOS app version 2.5.0, Chrome, Firefox, Safari, and Internet Explorer. Doesn't matter if I'm using a mac or ibm. see same error issue.
Thank you
Cameras connected to two Arlo base stations 10 miles apart have shown as "This base station is offline" since early this morning. Four exterior cameras in total, two connected to Cable One broadband and the others to CenturyLink DSL. No recording or live view available through web or iOS applications. Power and Internet LEDs lit on base stations but camera connection LEDs are dark.
HW Version H7
Serial Number 4N71677LFBACB
Firmware 1.2.16720
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.): 2 * VMB4000r3
Exact error message: offline
The application used (iOS, Android, Web): iOS, Web
Device Type: Arlo
Internet Service Provider: Cincinnati Bell
Exact Error Message: Your base station is offline. Check if it is powered up and connectes to the Internet.
Application Used: iOS
Please help!!
