Where Is The CVR Plan - I Can't see It?
I see in the App I can choose a Premier Smart Plan and a Elite Smart Plan. I see no other options for add a CVR plan. I want one of my cameras to do 24/7 recording. Where can I find the CVR option?
What version of the Arlo Mobile App are you using? Did you go to Settings > Subscription?
Did you log out and check again?
Do you see the CVR option on the Web Portal?
Have you purchased a CVR subscription? I have attached a link below with information regarding the CVR Subscription.
What is continuous video recording (CVR) and how do I get it?
Thank you for your reply. I am following the excact steps that you linked. I also trying by the website and CVR is NOWHERE to be found. I've purchased Arlo Smart Premier, and is still on the free trial. I've attached a screen of the subscribtion options, to show the frustration that it is not there.
Any advice?
I have attached a screenshot below for you. When on the web portal you should see the CVR Subscription under Settings > Subscription > Current Subscription & Plan
Do you have this option available?
This is what I see, there is no CVR options. Can you check my profile or something instead?
Is it possible to check this on a different browser & test again?
Internet Explorer 11(PC)
Chrome (PC)
Firefox(PC and on Iphone)
Edge(PC)
Safari(Iphone)
NO CVR option on either browser tried!
Any other suggestions??
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
