VMB5000 not updating firmware
TOEKNEEE
VMB 5000 not updating firmware. Arlo support says its system problem and not a problem with my unit. Is this true?
62 REPLIES 62
Edinburgh_lad1
Well, I can't do much with it, as it's not connecting any cameras. Otherwise I'd have left it the way it is.
Edinburgh_lad1
Hi @ShayneS
I've sent you a PM, but thought I'd post on here, too.
That's the base station online but it says the battery is too low to update firmware and I can't connect any cameras to it.
Would you please kindly look into this?
Thank you.
JC-
Getting message "a firmware update is required for this camera, but it's battery is too low to proceed.  However it's not a camera, it's the base station which does not have a battery
RichWood
I got that too. It was just a glitch. I called and was already on the most current firmware.
SaturnsEdge
Hello Community,
I am experiencing a critical issue with a "brand new, never used" Arlo Pro Base Station (VMB4000) that seems to be a widely known problem with very old firmware versions. I am unable to get the device to update automatically or manually.
The Issue:
My VMB4000 Base Station is stuck on firmware version 1.14.1.2_2916_1fdeefd, which I understand is significantly out of date (latest should be around 1.21.x.x). When I attempt to manually update the firmware via the Arlo Secure App (Settings > My Devices > Base Station > Device Info > Firmware), I receive a bizarre error message: "A firmware update is required for this camera but the battery levels are too low to proceed."
This message makes no sense as the device is a wired base station and has no battery. This appears to be a bug in the old firmware preventing proper communication with the update server.
Troubleshooting Steps Taken (All Failed):
I have attempted the following steps multiple times, as suggested in various community posts and support articles, without success:
  1. Manual Update Attempt: Failed consistently with the "low battery" error message.
  2. Power Cycling: Unplugged the base station, waited 30+ seconds, and plugged it back in. The device successfully comes back online, but no update is triggered, and the issue persists.
  3. Factory Reset: Performed a hard factory reset using a paperclip on the rear reset button (held for 15+ seconds until LEDs flashed amber).
  4. Remove and Re-add Device: After factory reset, I removed the device from my account and added it back as a "New System." The app claims it will update during this process, but after setup is complete, it remains on the old 1.14.1.2 firmware version.
  5. Checked Network: The base station is connected directly to my main router via a new, stable Ethernet cable. Internet speeds are fast (verified by speed test, well above 1 Mbps upload).
Request for Assistance:
Given that all standard user troubleshooting steps have failed and I cannot access live technical support, I believe this issue requires a manual intervention from Arlo support staff.
RamyS
Hi
I’m experiencing a persistent issue with my Arlo SmartHub where the firmware update fails to complete. I’ve followed all recommended troubleshooting steps, including restarting the hub, checking network connectivity, and attempting manual updates via the Arlo Secure app, but the problem remains unresolved.
Here are the details of my setup:
- Device: Arlo SmartHub
- Model: VMB4540
- Current Firmware Version: 1.28.2.0193853ee4a5
- Last Update Check: No update check yet (as shown in app)
- Connection: Ethernet to router, stable internet
- Issue: Firmware update fails repeatedly; app shows no update check or progress
Please advise on how to proceed. If a manual firmware push or deeper diagnostic is needed, I’m happy to assist with any steps required.
Or maybe  the version is the final version?
Thanks in advance
Ramy
denuitct
Base station has the message:
"A firmware update is required for this camera but its battery levels are too low to proceed".
However, it's a base station, it does not have any battery.
Clicking "Update" won't get the devices updated. This has been stuck for many days.
Have you tried turning the base off, wait for 10 seconds or so and then turn it back on? No guarantees...
denuitct
These are the things that I've tried:
  • Ensured the other camera batteries are full charged.
  • Restart the base station a few times.
  • Unplug the power and turn it back on a few times.
The problem still persists.
I gave up.
Today I checked again, it seems like the problem itself is gone, not sure why.
ShayneS
Hi @TOEKNEEE
Your device was updated to a firmware on the backend that should help with the symptom you were experiencing. Can you test this again and let me know how it goes.
alex_loo
Virtuoso
Virtuoso
@jguerdat wrote:
I looked at my 5000 to see if there was an update but nope. I then tried the Check for Update and got the attached error. @JamesC , @ShayneS , @BrookeN  is there an update for these hubs? I have 1.28.1.0_1940.
I missed this message back oct-2025 but now that it's dec-2025, I am still seeing the same error message above with my VMB5000, which has firmware 1.28.2.0_1941_53ee4a5
Kindly advise, @ShayneS @JamesC @BrookeN ?
Alex
Edinburgh_lad1
I presume what's happening here is that they have one error message to fit a range of  firmware search scenarios that result in 'no firmware available', in relation to either the camera or SmartHub or base station. Because of the poor wording of the message, it becomes confusing.
This app is a commercial product, not some kind of internal product made for the needs of the team where  everybody involved knows what the error message means, regardless of what it says. They should either reword the message or add another one, and be more aware of who the target audience of their product is.
ShayneS
@alex_loo
Your device was also updated to a firmware on the backend that should help with the symptom you were experiencing. Can you test this again and let me know how it goes.
alex_loo
Virtuoso
Virtuoso
@ShayneS wrote:
@alex_loo
hi @ShayneS , I don't quite understand you here but I tried it just now and it stayed showing the same "firmware could not be updated" screen as before.
In short, the issue has NOT been fixed.
Kindly advise.
Alex
ShayneS
@alex_loo
Thanks for the heads up, I'm checking on this now.
alex_loo
Virtuoso
Virtuoso
@ShayneS wrote:
@alex_loo
hi @ShayneS do you have any updates please?
Alex
jdfirth
I have the same issue, all cameras show firmware is up to date but the base station VMB5000r5 fails the update in the app. Everything is working in the Arlo app but I'm losing connection to smartthings. Not sure if this is related. Support - please advise.
alex_loo
Virtuoso
Virtuoso
I just noticed something just now.  Even though the "check for update" fails, I can see a "last checked" date as recent as my morning TODAY.  See screenshot below:
btw, @jdfirth , what is the firmware version number with your VMB5000?
Alex
jdfirth
Sorry Alex, meant to include that it's 1.28.2.0_1941_53ee4a5. Here's the error I'm getting when trying to check/update firmware in the app.  If I check in my.arlo.com it says firmware is up to date.
alex_loo
Virtuoso
Virtuoso
 my version was 129.0.0_1946_e67e68e
my "Last Checked" was Dec 16, 4:14am.
Alex
alex_loo
Virtuoso
Virtuoso
hmm ... this is interesting.
While I am still seeing above screen on the app, I happened to login via web browser, and when I check the firmware of the same smarthub from there, there was actually no issue at all !!  See screenshot below:
On web login screen, the last check date was even further updated (to Dec 17)!  vs the previous date which I re-post below:
(above: screenshot from yesterday's app, showing last checked date just Dec 16)
So, I am starting feeling that:
  • there is no further update necessary
  • Web version has no issue and working correctly
  • App (android here) version has issue by itself, and is reporting "cannot update" incorrectly
  • The app needs to be fixed
  • Users have not missed anything, and can just ignore that wrong screenshot from the app
Alex
alex_loo
Virtuoso
Virtuoso
Something went wrong and I am re-posting the missing picture here:
@ShayneS
Alex
I just checked both of my hubs (4540 and 5000) using the Android app (6.6.8) and also get that failure message. The web just says firmware is up to date.
ShayneS
The team is still investigating this. I will update the thread when I have more info.
alex_loo
Virtuoso
Virtuoso
to be honest, if this is just UI bug with the app, don't worry about that at this stage.  This is low priority and there are heaps of showstopper issues dev team should focus on.
To name a few:
  • pushing out good custom modes asap
  • fixing unreliable geofencing
  • fixing the geofencing in/out notification with iPhone app, that is simply not working
  • fixing issue that ARLO does NOT support "working with Google" claim --- it fails when user tries to link up ARLO to Google Home app, showing "HTTP 400"
I am sure there are more, but they are everywhere, ignored most of the time, within this forum.
Alex
