I now have basic smart on one camera but have 4 cameras in all. The smart notifications aren't working on that camera. In fact NO notifications are working on tgat camera.
Please help.
Did you restart the base? Are you getting videos? Is the camera armed?
Yes to all. Restarted through the app. Armed all devices and it is recording videos. Im just not getting any notifications on that camera that ive 'upgraded'
Exact same issue! Started on Nov 21st sometime. That was my last notification. I thought it was strange because it said, "All Other Motions" and I had never noticed that before. But nothing since. It's always armed and I never adjusted anything. I just rebooted my basestation to see if that helps any and went out to check it. Still nothing. Mine won't detect, notify or anything!
I've subscribed to arlo smart and enabled to be only alerted for person detection.
But the system does not appear to detect any person, vehicle or animal?
We have a dog in the house and when the camera is armed it only detects the dog as "motion" and not "animal"
Is the smart detection not working or?
Verify that the notifications are still set in your modes and rules. ALso, verify that notifications are allowed in the phone settings for the app. Possibly rebooting the phone will help or reinstalling the app would help.
Any insight? Or should I raise a support case?
I'm not sure smart notifications is working in the UK? It would be helpful to know if anyone in the UK has this working? I receive the rich notifications but get notified for all detections even if vehicles and animals are turned off. I just receive a motion detected alert.
I've just got off a rather length live chat with a representative and went through a lot of troubleshooting.
Was asked to remove and re-sync my cameras when I get back this evening, it is rather annoying but the due-process.
I do have a suspicion that the smart detection just simply isn't working in the UK it seems.
Will do.
Following from that what did they advise since it didn't work?
Are you still experiencing this issue? Which Device/Model/OS are you using? Do you have the latest version of the Arlo Mobile App installed?
I am having a similar issue for the past several days. Pro 2 camera is armed for motion and records motion but no longer getting notifications on my android phone or email notifications. No changes to phone and email settings. I restarted the base station but still no notifications.
@ShayneS The Arlo app on my Android Samsung S8 stops working when I place or receive a phone call.
I have only one camera with Arlo Smart to alert me and it's DEACTIVATED!
The other two that are activated don't do anything anymore.
I'm very frustrated and will soon be discontinuing my Arlo Smart (since it doesn't work as it should anymore.)
As you can tell from my screenshots included previously, I have it set to notify me when there's activity in my DRIVEWAY and my back porch. NOT for my front door. I have a Ring video doorbell for that. But now it's doing the exact opposite. I'm getting constant notifications for my front door but none for my driveway or back porch. I have package detection deactivated and sensitivity at ~80% for all cameras. Not sure what else to do. It's been like this for a couple of days now (since the 24th.)
Somebody screwed up with this latest update. ![]()
Arlo Pro 2, latest app, firmware, latest. vmb4000r3
Yes it still doesn't work and never has...
I have noticed that the time is incorrect on the notification.
Library time says 24hrs and Notification says 12hrs
For example:
Library = 20:30pm
Notification 08:30pm
It might be trying to pull a screenshot from a video clip that doesn't exist because of the time difference?
I also get 3 sound notifications for that camera!?
I have:
1. uninstalled and reinstalled the app
2. pared that camera again
3. logged out and back in again
4. restarted base station
5. took battery out and in on camera
6. uninstalled anti virus software
7. got refunded twice and bought smart for the 3rd time. still no luck
I have the same problem. Only "motion" notifications, nothing else. I have Premium subscription and live in Sweden.
Is this on an iPhone or Android? What os is it currently running?
Which version of android is your s8 running?
The subscription was successful but the 'smart feature is inactive. Why is this so?
Identical problem..all up to date and restarted everything...
Notification says ONLY "motion Alert" and for example 05.25pm whereas the library file says 17.25
Bill P
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
