Says it’s offline, can’t find where to switch it on
  • 1 Reply
  • 1348 Views
Paul-T
That's odd - you can't disable a hub like most cameras. WHat is the LED showing? Are any connected cameras working, which would show that the hub is also? You can try power cycling the hub to see if that helps.
