Receiving Incorrect Motion Notifications (Smart Notifications)
  • 5 Replies
  • 4776 Views
Shrick
Hi
Why am I receiving 'Motion' notifications on some of my cameras when the 'Smart Notifications' is ONLY set for 'People'. When the motion notifcation comes through, it also does NOT record to my library.
Please find attached configuration & info.
Thank You
5 REPLIES 5
JessicaP
Hi Shrick,
Did you check to make sure that you have your cameras on the "Active Cameras" on "Smart Notifications"? You can check this by going to Settings > "Smart Notifications" under Arlo Smart.
Shrick
Yes, all under 'Active'
JessicaP
Is this on the new Arlo app or legacy app? Have you tried reinstalling the Arlo app to see if that helps?
If you're still experiencing issues, contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link.
Shrick
The new app
JessicaP
I would suggest to contact the Support Team so they can assist you further regarding this.
