I have the basic subscription I want to update my subscription and add more cameras. How to do that.
  • 10 Replies
  • 4459 Views
Mosleh
10 REPLIES 10
go to settings, click on subscription and change plan to the next level ( or higher )... pay  monthly fee and your G2G
Mosleh
Thank you for your reply. I do not have any choice for upgrading. Please look at the attached photo.
Regards
JessicaP
Hi Mosleh,
Please refer to this article to learn which country supports Arlo Smart subscription: What are the available Arlo subscription plans and how much cloud recording is available?
Mosleh
Thank you Jessica for your reply
I am from Jordan. My country is not in the list. I do not know what to do to add more cams to my subscription.
JessicaP
At this time, we only support Arlo Smart subscription at countries that are listed on that link.
Mosleh
Hi Jessica
greetings
is there any other way to add more cams to my subscription, already bought five cams.
is there any solution to make my sub. 10 cams instead of five. with payments.
regards
mosleh
You can't get a subscription if you aren't in a country where they are offered.
But if you have two base stations, you can set up two basic (free) accounts, and share the cameras accross the two accounts with "grant access".
Of course if you only have one base station, you can purchase another.  That would improve performance, especially when you have multiple motion events near-simultaneously.
Mosleh
Thanks a lot. Yes I bought another base stations. So how can I grant access. Is this secured no one can access my cameras. What are the steps for grant access. So I need to create another email and create another account. Right?
Yes.
https://kb.arlo.com/000039122/How-do-I-add-friends-to-my-Arlo-account
Mosleh
Thanks a lot
