How to record only animal motion
  • 8 Replies
  • 10038 Views
vetrijar
I have the Arlo pro 2 with CVR running. Also the smart feature is enabled. I can adjust the notifications for the smart feature to only alert me when an animal walks by (I disabled notifications for people & vehicles). So this works for notifications.
The issue is with the recordings. I still get a bulk load of recorded videos to filter through which include people and vehicles. Over 100 per day. I'm on a busy street and mainly trying to capture the animals. Is there a way to only record animals and not store the recordings of everything else?
ShayneS
The videos will upload to your library as normal regardless off smart setting. However, your push notifications will be adjusted to your settings provided People (ON) Animal (OFF) etc.
Have you tried using the filter funnel to pick your desired videos?
8 REPLIES 8
ShayneS
Hi @vetrijar
Have you tried to reboot your base station & test again? if that does not help, you may try and remove the cameras from Settings  > My Devices > Re-Add.
vetrijar
Tried that. Did not work for me. Everything still is recorded. Question is, can the Arlo camera record ONLY animals and nothing else?
ShayneS
Have you tried contacting customer support regarding this issue? I have attached the link here for you - Arlo Tech Support
vetrijar
I have only tried in the community forum hoping to get an answer from here. I'm guessing it's an unknown if recordings can be restricted to only animals? Which is fine, I just don't know if that's true or not
ShayneS
Does your web browser display the same settings as your App for the animal notifications? You can also try to remove the camera(s) from the active Smart enabled cameras list to inactive then add it back > reboot.
ShayneS
vetrijar
Thanks, that helped clear it up for me with understanding how the recordings work.  So basically all motion is recorded and stored on the cloud (regardless of the smart filter/notifications).  If I set the smart notifications to animal detection only (people,vehicle,motion are all off), then I will still have recordings of all activity, but I will only get a notification alert on my phone when an animal walks by.  From my understanding with the cloud storage, it won't matter if I have 10 videos a day or 200 videos a day recorded. It's unlimited until the old videos get deleted.  I can just filter out the videos I don't want to see anymore.
Thanks for the info.
ShayneS
You are very welcome. Just to note, the expiration of a video will depend on the current plan.
