CVR Timeline not working on iPhone
  • 4 Replies
  • 2882 Views
hjscm
I Purchased the CVR plan for one of my cameras.  I saw an old post from 2 years ago stating the timeline doesn't work on iOS, just wondering, i know its only been 2 years but when will it be fixed? I can not access the timeline on my phone, Works fine from computer.  Any idea when it will work?
ShayneS
Hi @vhjscm
Which model of iphone are you experiencing this issue with? What OS is the phone running & which Arlo app version?
hjscm
Iphone X, iOS 13.1. Arlo is 2.12.3(1927)  I even tried the developer iOS 13.4.  Under timeline all i get is live view.  If i scroll by hand it shows nothing and just jumps back to live view.  Works fine on computer.
ShayneS
@hjscm
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Arlonotgood
Same problem! Timeline doesn’t work at all, frustrating paying for a product that doesn’t work! Made multiple calls to Arlo and still doesn’t work. Would just return everything and go with Ring if we didn’t have to start over
