  • 1 Reply
  • 2360 Views
ArloInvested
Normally everything runs fine with my Arlo setup. But now I have invested in an Arlo Smart plan and to begin with everything is fine. But now Smart notifications are all over the place. Wrong cameras send notifications, some cameras won't send any at all etc.
Disable Arlo Smart and everything works fine.
I tried resetting the Base Station (which is a hassle) and had to redo everything. But still when enabling Arlo Smart everything just messes up or stops working.
Contacting support has not helped at all. 1st line simply sends me FAQs on setting up notifications.
Why charge so much extra for Arlo Smart that it basically does not do what it is supposed to?
rapheal21
hey,
I was just going through your post and came to know about your query. I think the issue that you are facing is due to some bugs or it requires a firmware update hope so. I will suggest you to wait and see if there comes any update or not and if there comes an update you must do it and then I hope there will be no further issues.
thanks!
https://macysinsite.club/ https://mypascoconnect.today/
