  • 4 Replies
  • 2756 Views
tyele
hey, is anyone having problems wit the flood light can color? when i manually turn on the floodlight. it is bright and white. but when motion is detected the light is a weird yellowish color and it is not as bright. also how can i set the light to stay on longer during motion? as right now it only turn on for 2-3 secs if that then off.
You prob are in the wrong place....
the color and time for motion is edited in the mode you are using to trigger the light ( not the manual on/off )
You can edit the duration and color in the settings
tyele
thanks for the reply but i have duration set to 5 mins. and color set to white. but it seems like those settings are only for when i manually turn it on. not when motion is detected. am i missing something here?
tyele
thank you i finally figured it out! appreciate your help!
  • 4 Replies
  • 2757 Views
