Arlo Light help
  • 2172 Views
Arlopro1977
My wireless interface will not sync to my router. I scan the bar code and plug it in and it stays purple. Does not blink or turn amber. I have set my router to 2.4 ghz and still nothing. What can I do? Please help
do a reset on the Bridge and try again
https://kb.arlo.com/000061857/How-do-I-perform-a-factory-reset-on-my-Arlo-Bridge
Press and hold the Sync button on the bridge for about 15 seconds until the status LED changes to solid amber and then release the Sync button. In about 90 seconds, the LED changes to blinking amber. This indicates that the factory reset is complete
Arlopro1977
Bridge remains solid purple... at this point it’s been 2 days of trying different things to get these lights working. Why won’t it connect to my router? My router is a NETGEAR wnr200v4 is this compatible?
Arlopro1977,
It sounds like this is a hardware issue with the bridge. Are you able to exchange the bridge? If not, please reach out to me in a private message so I can connect you with the support team for potential RMA.
  • 2173 Views
