  • 25 Replies
  • 1876 Views
  • 13 In Conversation
jrager
Have two AL1001R4 lights connected to an Arlo bridge.  Have had these armed on a schedule for a few years with no problems.
A couple of months ago I noticed that neither of them were arming any more when they should.  I went into modes in the app at a time when the lights should be armed, selected "disable", then "schedule", and they armed.  The exact same thing happened at the disable time - they stayed as "armed".  I again went into modes in the app, selected "disable", then "schedule", and they disarmed.  The behavior has been this way ever since.
I also have three cameras connected to the same bridge, on a schedule, and these have worked with no issues all along.
I've power-cycled the base, power-cycled and reset the bridge, removed and re-added the lights, removed and re-added the schedule for the lights on both the mobile app and the Arlo website, and I'm still having this issue.
Nothing changed as far as I'm aware that could have caused this.  The system obviously realizes when the lights should be armed or disarmed, it just doesn't see it unless I change the mode to something other than schedule and change it back.  This is of course not something I should have to do twice every day - schedule mode for my lights is basically useless at this point.
Please let me know what I need to do to fix this.  Thank you.
25 REPLIES 25
jrager
Just noticed several earlier posts from others about similar issues over the past several months.  I don't see any solution that has worked reliably.  Though it's comforting to know this isn't just me, it's alarming to see no diagnosis or resolution.
Please don't suggest resetting/removing/re-adding - I've reset everything, removed and re-added all devices and schedules except for my cameras and I certainly don't want to do that as they are working - I'm not going to risk this issue bleeding over to them.
Has Arlo determined what the issue is, and if so when will the fix be available?
ShayneS
Hi @jrager
I notified the team and I am waiting for more info regarding your symptoms. I will report back as soon as possible.
ShayneS
Hi @jrager
The symptom you're experiencing should be resolved in a future update, at this time we have a test firmware that we put your device on. Can you reboot your base station and unplug/replug the bridge and test again?
jrager
Thanks for getting back to me Shayne,
I rebooted the base station and unplugged/replugged the bridge, and from what I can see this fix is working.
I put in a test schedule to arm the lights from 11:05am to 11:10am and watched mode on the app, and I saw it change from disarmed to armed and back to disarmed correctly.
I believe this issue is resolved, but I'll check again tonight and tomorrow morning when the typical schedule is set to run.
I really appreciate the fix being made available.
Thank you,
John
ShayneS
@jrager Thank you for the update.
manojpatel77
Hi I have the same problem. How do I access the test firmware please?
ShayneS
@manojpatel77 I notified the team and I will report back as soon as possible.
ShayneS
Hi @manojpatel77
Your devices were placed on the test version as well.
Bbprthead
I have been experiencing this issue for several months as well. Can I please be added to this “test” case as well??
Stelly22
@ShayneS am I also able to access the test firmware? I’ve  been experiencing the same issue the OP described for quite some time. Thank you!
ShayneS
@Stelly22 I notified the team, I will let you know when this occurs.
fritzKU
Have this same problem!!! When is a permanent fix gonna happen?
BV28
I have the same problem with the schedule mode for the Light Bridge that does not arm or disarm the lights based on the set schedule. I have to manually arm and disarm the lights. Like others, I have rebooted the light bridge, removed and readded the schedules. The schedule mode for the cameras works fine. I'm using the Arlo Secure app v5.0_258726.   I read that a firmware update is supposed to fix the problem. When will the update be available and how will I know to apply it? The firmware version on the light bridge is 2.0.1.0_307_376
Stelly22
@ShayneS the new test firmware seems to have fixed the problem. Thanks for your help!
ShayneS
@Stelly22
Thank you for letting me know.
D1132
I have the same issue. Please add my device on test mode.
JerryinFL
Good afternoon.  I have been having this same issue for a few months and finally looked at this forum.  If there is a fix please include me.  Thanks.
D1132
Hi, ask to someone of the staff (@ShayneS) in this tread to add you at last version of the firmware, this solve your problem. You have to find 2.0.1.0_309_383 and just work properly.
MavHaven
Hi @ShayneS - please add my light bridge and account to the test firmware as well for the safety and security of my family. I need this to be working, especially having had Arlo products for 7+ years now, along with a paid  subscription
dazednconfuzd
Shane, I have a similar problem. Arlo Pro 3 lights and cameras all come on at the same time when they enter schedule mode. I’ve redone the schedule, deleted and recreated the rules. And even did a factory reset on the base station but nothing prevents them from turning on when they enter schedule mode. Really frustrating. Is this an issue that needs a test firmware (?) also?
dazednconfuzd
I might add, I have the base station plugged into an eero mesh node.
ShayneS
@dazednconfuzd
Can you create a new thread for me with these details and tag me and I will have someone take a look?
PHATBOYPIMP
I have been having this same issue - can I be updated to the Beta Firmware that solves this particular issue?
PHATBOYPIMP
@ShayneS - any chance I could get this firmware beta?
