One of the Arlo Security Light System is not working
  • 4 Replies
  • 2005 Views
Wildbillg
Just got 2 security lights and after I got them installed, one I was not working. I removed it, then re-added it. It works but there is no Firmware or hardware numbers. The first one checked for updates, this one did not and I can’t see how to update the firmware thru the settings. Any suggestions would be great.
steve_t
Master Master
It's working fine with the rule for it and you can manually turn it on and off through the app?
You might be able to trigger a firmware update by power cycling the bridge
Wildbillg
Thanks. What do you mean by “power cycling” the bridge and how do I do that.
Also, is there any way to keep the lights on longer than the 10 seconds they stay on now when they detect motion?
steve_t
Master Master
Power cycling means unplugging it and plugging it back in since it has no on/off button or switch.
Yes, you need to edit the rule for the bridge, probably Armed, and change the length of time it stays on. It can stay on up to 2 minutes when motion activated and indefinitely when manually switched on
Wildbillg
Thank you so much for the help. Much appreciated.
  • 4 Replies
  • 2006 Views
