New Arlo Security Light and Solar Panel
  • 5 Replies
  • 8676 Views
  • 3 Likes
  • 5 In Conversation
SoCalMom
Does the new Arlo Security light work with the solar panel currently sold that works with the Arlo Pro camera?
yes... the camera and light also use the same battery pack
5 REPLIES 5
tkaser1
This app will not let me select exactly what I need as it is not listed     is there a trick to connect and get to work? ive tried and each time i get the orange ! Symbol ⚠️
RobertDavidLyon
When I plug the Solar panel into security light all I get is a blinking lighting bolt not a solid charging lighting bolt and the solar panel is in direct sunlight.
If I plug in the Arlo wall charger i have no problem charging.
That's a new one for me. I kinda sounds like something is making contact and then not. Remove the cable from both ends and reseat them, making very sure that they are completely seated. They can be a royal pain to do so.
RobertDavidLyon
Thanks I will give that a go
  • 5 Replies
  • 8677 Views
  • 3 Likes
  • 5 In Conversation
