Light Senses Movement But Doesn't Turn On
  • 1 Reply
  • 1968 Views
SCMiller
I have 2 security lights and they are both set up the same.
One light works perfectly... the light turns on when it senses activity.
The second light doesn't turn on.  I have confirmed that it senses motion based on the sensitivity tool but the light doesn't turn on in response to motion.  I know that the light works because I can manually turn it on.
Please help!
Check the setting for the amount of darkness to turn on..... called DAWN TO DAWN SENSOR ( in settings of light )
If the adjustment is incorrectly set or there is too much light in the area, the Spot/Flood light will not turn on.
  • 1 Reply
  • 1969 Views
